Activity Forums Adobe After Effects mask madness – ready to kill again
  • mask madness – ready to kill again
    Posted by Antony Buonomo on October 25, 2005 at 3:37 pm
    Why does this happen?
    See link – https://www.vertigo.co.uk/mask_z_weird.jpg
    I switch off the camera, trace the river on a new solid layer, add stroke, switch the camera on again – all is fine… until I turn on ‘continuous rasterization’. Then the line shifts in a major way – yellow is mask, dark blue is stroked, rendered line. If I switch views it hasn’t moved. I can pre-comp it BUT I SHOULDN’T NEED TO!
    A
    Antony Buonomo replied 20 years, 11 months ago 4,598 Members · 2 Replies
  • Antony Buonomo
    October 26, 2005 at 9:54 am
    Thanks Dave
    I have had to make-do by putting the path onto the map-layer, mostly because I have no idea why the solid layer is not aligning with the map-layer
    https://www.vertigo.co.uk/solid1.jpg
    https://www.vertigo.co.uk/solid2.jpg
    As you can see, all the parameters are the same and the layers are exactly the same size, yet they are way off.
    Any ideas?
    Antony
  • Antony Buonomo
    October 26, 2005 at 4:32 pm
    I have Dave, thanks.
    But why do you say the two layers are not the same size? If you look at the info in the project window you will see they are both 3334×2757 and both scaled to 40%. How are they different?
