Activity Forums Adobe After Effects Mask is warping when I try to move a layer
  • Mask is warping when I try to move a layer
    Posted by Sean Cole on June 12, 2015 at 11:48 am
    Hi all,
    I’ve been using AE for about 20yrs now and never encountered this I think. Selecting a layer from the timeline (a photo image) that has an ellipse mask applied to it. As usual the mask is not locked. I am sure to select the layer, not the mask. In the viewer I attempt to move the layer image but all it does is warp the mask shape, i.e., two of the beziers are adjusting length and angle. Even if I select right in the middle of the circle. Even if I am zoomed right in.
    I can’t think what I might have switched on to cause this effect. I’m sure it is handy at times but right now I have to keep locking and unlocking my masks which is not very productive.
    Any ideas? Have you come across this in the past? What is it that I’ve switched?
    All the best
    Sean
    Sean Cole replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
