Activity Forums Adobe After Effects Expressions Mask Index linked to Layer index
  • Mask Index linked to Layer index
    Posted by Criis Daw on November 26, 2015 at 10:38 am
    Can anyone help me.. I am digging myself into a hole trying to solve a problem that might not even exist.
    I have a a psd layer with with lots of individual elements, some of which I would like to isolate and animate on different layers in 3d space.
    Rather than cut out each layer in photoshop and import a layered file I have been trying to take a short cut (which obviously has become a long cut .. but hey is the journey not the destination) and do it in after effects.
    My rational is to draw a mask around each element that i wish to isolate on one layer.
    I then want to add an expression that says
    if the index number of this mask equals the index number of this layer then set the mask opacity to 100% else 0%
    this should then allow me to draw masks on one layer then simply duplicate the layer (potentially 50+ times) and each layer will only have one transparent (on) mask and display only one element.
    i have been trying to use: thisProperty.propertyGroup(1).propertyIndex
    but i dont really know what i am doing or even if its a particularly efficient work flow. but any help will be greatly appreciated.
    Cheers
    Criis Daw replied 10 years, 9 months ago 2 Members · 13 Replies
  • 13 Replies
  • Martin Jean-sébastien
    November 26, 2015 at 1:36 pm
    Hello,
    You have to select all the layers where you want to apply this script :
    app.beginUndoGroup(“Set opacity mask”);
    for(var j=0;j
    November 26, 2015 at 1:37 pm
    Unknown issue of copy/paste here, type this :
    for(var j=0;j
    November 26, 2015 at 1:38 pm
    Oh i try this
    app.beginUndoGroup("Set opacity mask");
    for(var j=0;j<app.project.activeItem.selectedLayers.length;j++){
    var myLayer = app.project.activeItem.selectedLayers[j];
    var myPath = myLayer.property("Masks");
    var numMasks = myPath.numProperties;
    for(var i=1;i<numMasks+1;i++){
    if(myPath.property(i).name.replace(/Mask /g, "")==myLayer.index) myPath.property(i).maskOpacity.setValue(100);
    else myPath.property(i).maskOpacity.setValue(0);
    app.endUndoGroup();
  • Criis Daw
    November 26, 2015 at 1:39 pm
    thanks..
    thats way more complicated than I imagined !
  • Criis Daw
    November 26, 2015 at 1:43 pm
    worked a treat .
    thanks..
  • Criis Daw
    November 26, 2015 at 1:53 pm
    now i am in really uncharted waters here but could a script be used to delete masks instead of turning the opacity to zero ?
    this would be an ideal work flow but it never crossed my mind as I was approaching it from an expression point of view …
    November 26, 2015 at 2:03 pm
    Here it is
    app.beginUndoGroup("Delete mask");
    if(myPath.property(i).name.replace(/Mask /g, "")==myLayer.index){
    myPath.property(i).remove();
    numMasks = numMasks-1;
    app.endUndoGroup();
  • Criis Daw
    November 26, 2015 at 2:07 pm
    thanks thats brilliant..
    except it works the wrong way around. It keeps the ones I want to delete and deletes the one I want to keep…
    November 26, 2015 at 2:11 pm
    else{
    app.endUndoGroup();
  • Criis Daw
    November 26, 2015 at 2:19 pm
    appreciate your efforts here but that’s still not doing it.
    each layer have 50 identical masks . Turning off the opacity of the 49 i didnt want to see worked fine but deleting them hasnt worked.
    this time it deleted mask 2 on layer 1 and left the rest . On the other layers all the masks see the same as before..
