Mask in DVDA3
Posted by Chase Mccullan on January 6, 2006 at 11:05 pmI have a bit of a problem, I forgot to put a mask on my video when I rendered it so that stuff between the tv and computer safe views wouldn’t be seen. I was gonna put a black border (using a mask). I didn’t know how to do a mask, and I forgot about doing it. I ended up rendering the video, and I don’t want to re-render it. Is there any way to do the mask in DVDA? If thats possible I’d really appreciate an explination, thanks so much.
Stephen Mann replied 20 years, 8 months ago 4 Members · 10 Replies -
Gary Kleiner
January 7, 2006 at 12:04 amThere is no way to add a mask without re-rendering.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Chase Mccullan
January 7, 2006 at 7:02 pmThanks for the reply, even if it wasn’t the answer I was hoping for. Would you be able to direct me to a tutorial or explain how to do a mask so that I could make a simple black border throughout my movie. Thanks again.
Edward Troxel
January 7, 2006 at 10:01 pm -
Stephen Mann
January 9, 2006 at 4:18 amWhy would you want to? The ‘safe area’ is arbitrary anyway.
Steve
Chase Mccullan
January 9, 2006 at 1:09 pmbecause, if someone were to play the DVD in a computer, they would see that area and the overlap of the video behind it.
Stephen Mann
January 10, 2006 at 7:31 amAnd, that’s a problem…. why?
As I said, the safe area is arbitrary anyway so no two TV receivers will be the same.
Edward Troxel
January 10, 2006 at 3:02 pmHe said WHY it was a problem. His solution is to make his OWN “safe area” by blacking out what he doesn’t want people to see.
The alternate solution would be to only use full screen where “off the screen” was the safe area. However, that might chop some things off when viewing on a TV.
I agree that it’s somewhat arbitrary what you use for the safe area. In this case, he simply had some things that were visible in some circumstances that he did not want visible in any circumstance. Hiding them is a very viable solution (especially if it meant re-editing the entire project).
Now… for future projects…
Chase Mccullan
January 11, 2006 at 12:18 amSo, for future projects, what would u recommend? Using the entire space (even the safe area), keeping in mind not to put anything important there because it will get chopped off on TV?
Edward Troxel
January 11, 2006 at 1:18 am -
Stephen Mann
January 11, 2006 at 7:37 am“Assume the entire [screen] is going to be seen but keep all “important” part inside the real safe area”
Chase – This is all that the safe area is. It’s a guide – nothing more.
Steve
