Activity Forums Adobe After Effects Mask , I need more corners
  • Mask , I need more corners
    Posted by Linus Källman on June 1, 2005 at 4:39 pm
    Hi, I want to make a mask into my prject so that I can use my effect in the mast. The problen is that when I dragg the corners on the mask both sides get smaller or bigger (high and widht). I want to change the size and form og my mask as I want. How to to that? I know when I used i adjusment layer I could to that but not with a mask?
    Filip Vandueren replied 21 years, 3 months ago 2 Members · 1 Reply
  • Filip Vandueren
    June 1, 2005 at 5:42 pm
    You’re probably scaling the mask instead of changing the points,
    make sure you have the pen-tool selected to edit paths.
    And check the manual and some basic tutorials please, this is pretty basic stuff 8-/
