Activity Forums Adobe After Effects mask help
  • Posted by Bingston on September 10, 2007 at 12:17 am
    i’m trying to make a short clip with a football helmet that has a sword come down and stick in the helmet. when i move the sword in the screen the mask moves with it. how can i get the mask to stay in the same place as the sword comes into the screen? or is there a way to put the mask on the helmet and affect the sword layer as it comes in. seems like i’ve had this problem before but i can’t remember how i got around it. any help is appreciated. thanks
    Steve Roberts replied 19 years ago 3 Members · 4 Replies
  • Steve Roberts
    September 10, 2007 at 12:26 am
    Have two helmet layers, with the sword sliding in-between. Mask the upper helmet layer so you can see the sword, well, until you don’t want to see the sword.
    So I guess the mask would allow you to see the sword below up until the point where it enters the helmet — at that point you’d let the upper helmet layer cover the sword, no?
  • Bingston
    September 10, 2007 at 12:29 am
    thanks
  • Kevin Camp
    September 10, 2007 at 12:35 am
    or you could use your mask on a separate layer and use that layer as a track matte for the sword layer…
    it’s the same amout of work, and the same result, just another way to work…
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Steve Roberts
    September 10, 2007 at 12:48 am
    Indeed. 🙂
