Activity Forums Adobe After Effects Mask following tracking points
  • Mask following tracking points
    Posted by Per Spook on June 12, 2008 at 7:54 am
    I have a shot where I need to change the eyecolor of a subject. The shot has a lot of camera movement, so the easiest way would be to track the eyes and connect some masks to the tracker.
    Can anyone help me out with how to connect a mask to a tracker?
    thanks
    Per Spook replied 18 years, 3 months ago 3 Members · 3 Replies
  • Chris Wright
    June 12, 2008 at 8:46 am
    1. Tracker can be set in tracker options to set copy keyframes to a thing called a Target. or manually…
    2. parenting
    3. copy and paste keyframes in transform. You’ll want to do full motion tracking, movement, size, rotations. Make trackers sandwiched between what you want to track.
  • Mike Clasby
    June 12, 2008 at 7:18 pm
    I think Aharon does what you want in Part Three at about five minutes to tweleve minutes, here:
    https://library.creativecow.net/articles/rabinowitz_aharon/cartoon_look.php
  • Per Spook
    June 17, 2008 at 11:07 am
    what I mean is to attach a mask path to a tracker point, not a layer which is the obvious choice..
