Activity Forums Adobe After Effects mask following tracker data
  • mask following tracker data
    Posted by Gunnar Kordestani on March 6, 2009 at 8:32 am
    hi everybody,
    I have a handheld shot here. Camera is following a guy and there are some sun reflections to cover.
    As Camera is not stable the reflections are moving too. I thought to track the reflection and the apply the x and y position of my track to the position of the mask I am drawing. I use the footage with less brightness to cover, so I cant move the whole Layer.
    I cant figure out how to let the position of the mask follow the “Feature centre” property of my tracker.
    The shape of the mask does not change during the shot. I guess it would be via the “mask path” property of the mask I want to use. But I don’t find the right way to connect these two.
    any suggestions are highly appreciated
    Gunnar
    Paul Hennell replied 17 years, 6 months ago 2 Members · 1 Reply
  • Paul Hennell
    March 6, 2009 at 9:56 am
    I believe the best way to do it is to use a black solid with the mask and applying the tracking data to that. Then you can use the solid layer as an alpha mask.
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
