Activity Forums Adobe After Effects Mask feathering creates hard line?
  • Mask feathering creates hard line?
    Posted by Omur Sonmez on December 7, 2015 at 10:58 pm
    Hello,
    I have a shot where I have to merge two backgrounds and try to do it seamlessly. It works to an extent when I mask one part over the other, and just feather it out because they’re a bit alike. But no matter how much I feather, there is always this obvious hard line in the feather that moves unnaturally.
    Is there a way how I can just create a soft transition that isn’t too noticeable?
    Thanks in advance.
    Omur Sonmez replied 10 years, 8 months ago 2 Members · 4 Replies
  • Omur Sonmez
    December 8, 2015 at 9:03 am
    I try to move the feathering, but the line moves along with the mask. There also isn’t an edge that close. It’s like a noticeable line in the middle of a soft feathering.
  • Walter Soyka
    December 8, 2015 at 3:00 pm
    [Omur Sonmez] “I try to move the feathering, but the line moves along with the mask. There also isn’t an edge that close. It’s like a noticeable line in the middle of a soft feathering.”
    Can you post a couple screenshots showing your UI and the problem you’re having? It would be great to see a sequence of screenshots showing each layer in the composite as well as the mask itself.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Omur Sonmez
    December 9, 2015 at 8:30 pm
    I moved the mask to make it more noticeable. But it’s really only noticeable when it’s in animation. I just crank up the feathering. But there’s always a hard line present. It’s close to the center in the first picture.
  • Omur Sonmez
    December 10, 2015 at 10:39 am
    It’s not the red line,
    I’ll try to zoom in a lot more or a way that it’s more noticeable.
