Activity Forums Adobe After Effects Mask Expansion question
  • Mask Expansion question
    Posted by Riccardo Sinti on June 12, 2009 at 2:50 pm
    I have a rectangular mask that I applied a positive expansion value to and the result is rounded corners.
    Why is this?
    Negative values maintain the 90 degree corners.
    I don’t recall this happening before, so if this is normal behavior then sorry for the dumb question, but it would be nice if a mask with hard angles maintained them when expanded.
    Thanks for an info!
    Curt Needs replied 9 years, 8 months ago 4 Members · 4 Replies
  • First Last
    June 12, 2009 at 4:36 pm
    I never noticed that before and I can’t figure out why it does that.
    Is the expansion absolutely necessary? What’s the effect you’re looking for? There’s probably a work around.
    Production Associate
    Bend, Oregon, United States
  • Riccardo Sinti
    June 12, 2009 at 4:39 pm
    Well, it’s just easier to use expansion instead of mask shape sometimes.
    And sometimes you have lots of mask shape keyframes and you just want to expand the mask without tweaking all those shape keys.
    Thank You
  • Todd Kopriva
    June 13, 2009 at 7:05 pm
    Increasing mask expansion is not the same thing scaling a mask. Scaling preserves shape. Expansion says “Make it bigger by growing outward from each point a certain number of pixels.”
    For each point on the original mask path, imagine a circle radiating outward by the number of pixels by which you’re expanding.
    I’ve embedded an image below that should show what I’m talking about. The white rectangle is the original mask path. The red circles indicate the expansion radius. Note how these circles define a sharp inner rectangle, which is what you get with a negative expansion; and they define a rounded outer rectangle, which is what you get with a positive expansion.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Curt Needs
    December 29, 2016 at 10:47 pm
    It would be a nice feature if we could have the option to expand a mask and keep the points. Since we don’t have a Mask Scale in the drop down, it would be nice to have the option to use Mask Expansion and click a box on whether we want it to expand as you describe it or scale as most people seem to want it to do.
