Activity Forums Adobe After Effects Mask duration
  • Mask duration
    Posted by Phillip Thurmond on July 17, 2010 at 9:32 pm
    I feel like this may be a very stupid question, but I haven’t been able to find it in the tutorials I’ve been following.
    I am using an animated mask to color correct the sunlight coming in through a door that is opened and shut during a scene. I’m using a mask wich has a keyframe for each frame the door is open and it looks great. Problem is, I don’t need the mask after the door is shut. How do I limit a mask to a certain number of frames in a clip? Thanks.
    –Phillip
    Marcel Ooms replied 16 years, 2 months ago 3 Members · 2 Replies
  • Andy George
    July 18, 2010 at 2:31 am
    Hi Phillip,
    The easiest method is to just split your layer at the point where you no longer need the mask. Under EDIT>SPLIT LAYER. The shortcut is CMND+SHIFT+D if your on a mac.
    Then just delete the mask from the 2nd layer.
    -Andy George
    Senior Editor
    http://www.chiselindustries.com
  • Marcel Ooms
    July 19, 2010 at 10:42 am
    I always just keyframe the mask position and then drag it off the screen to make sure I don’t get a bunch of unorganized layers
