Activity Forums Adobe After Effects Mask doesn’t have “add” or “subtract” button
  • Mask doesn’t have “add” or “subtract” button
    Posted by Stan Heard on May 23, 2009 at 10:22 pm
    I have a recurring problem: When drawing a mask in CS3, the Mask dropdown menu often doesn’t have the “add,” “subtract,” etc choices. Does anyone have a suggestion? Often I will delete the mask, draw a new one, and the choices are there. Thanks!
    Buck Miller replied 14 years, 7 months ago 4 Members · 3 Replies
  • Immanuel Morales
    May 24, 2009 at 3:09 am
    in the timeline, at the far bottom left, there are 3 icons, play with those a bit to make sure you have all data turned on. also, in the timeline, right-click (command+click) on where it says “Source Name” and make sure columns/Modes is checked off
    Dead the Fed
  • Roland R. kahlenberg
    May 25, 2009 at 11:13 am
    Mask Modes are only available for closed paths/shapes. Perhaps this is your issue?
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Buck Miller
    January 10, 2012 at 2:53 am
    Just had the problem and found this thread. For me, it was that I had not actually competed the mask. I was drawing one using the pen tool, and got close but not right on the starting mask point, so if you have the lack of “add” “subtract” options, be sure you closed the mask.
