Activity Forums Adobe After Effects Mask deleted but persists
  • Mask deleted but persists
    Posted by Dan Kelly on May 16, 2014 at 1:01 am
    I’ve deleted a mask from a layer but it persists. See screen capture, notice the only visible layer has no masks, but the composition shows a slightly transparent vertical mask shape, running down the center of the right image. That was the mask that was deleted. I swear there’s no hidden alpha channels in the image, there really was a mask there, things were acting wonky so I deleted it, but it’s haunting my layer. Ideas? No obvious ectoplasmic residue around my work area. Apple OS 10.8.5 and AE 11.0.0.378.
    Dan
    Dan Kelly replied 12 years, 3 months ago 3 Members · 4 Replies
  • Darby Edelen
    May 16, 2014 at 4:16 am
    Is there anything inside the pre-comp that could be causing that? Have you purged your caches recently?
    Darby Edelen
  • Michael Szalapski
    May 16, 2014 at 3:36 pm
    I agree with Darby that you should purge your cache, but also, you are very out of date on your CS6. You should be on version 11.0.4. You are missing 4 bug fix updates.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Dan Kelly
    May 18, 2014 at 1:04 pm
    Ok, I will update and purge and report back with results. Thanks very much.
  • Dan Kelly
    May 19, 2014 at 10:57 pm
    That fixed it, thanks!
