Activity Forums Adobe After Effects Mask Data Used As Camera Path?
  • Mask Data Used As Camera Path?
    Posted by Bernd Garving on July 13, 2005 at 4:54 pm
    Hi there …
    … I’d like to use data of a elliptical mask as data for the path of a camera. I copied the mask’s shape into camera’s position. But what do I have to do to tweak it into the right dimension?
    Thanks in advance.
    Bernd Garving replied 21 years, 2 months ago 2 Members · 2 Replies
  • Mylenium
    July 13, 2005 at 6:06 pm
    I m not exactly sure I understand what you mean, but mask data is 2-dimensional and will end up in the X and Y position values. Z is just left empty (assumed to be zero). If that’s your problem, just switch the values using a simple expression.
    X=position[0];
    Y=position[2];
    Z=position[1];
    [X,Y,Z]
    [Pour Myl
  • Bernd Garving
    July 15, 2005 at 5:31 am
    Hi Mylenium,
    thanx for your tip. That’s exactly what I needed.
    Regards from Germany to Germany.
