Activity › Forums › Adobe After Effects › Mask a solid?
  • Mask a solid?
    Posted by Alex Edbay on July 26, 2017 at 6:15 pm
    I’m creating an effect with a generated lightning in a solid. I have the original footage which is a lake and a tree. I want the lightning to go behind the tree. So I tried making the lightning effect within a solid layer. But when I draw a mask around the tree in the solid layer, the mask won’t affect anything. Anybody knows why?
    Andrei Popa replied 9 years, 2 months ago 3 Members · 2 Replies
  • Michael Szalapski
    July 26, 2017 at 6:37 pm
    You are using the Advanced Lightning effect and not the obsolete Lightning effect, right?
    Regardless, the effect generates on the layer source regardless of masks. If you are using the most current release of After Effects, the easiest thing to do would be to paste that mask onto a different solid and then, on your lightning solid, apply the Set Matte effect, point it at the new solid and set it to use the alpha of that layer after masks and effects. If you’re using an older version of AE, the same applies except that you will need to precompose the new layer with the mask (moving all the attributes, etc. into the precomp) and point the Set Matte effect at the new layer.
    I would also highly recommend removing the glow that the lightning effect creates itself and create your own glow (after the Set Matte effect). It’ll look much better (even if you weren’t needing to mask it out). See the very recent lightning tutorial at VideoCopilot.net for some great tips on getting better-looking lightning.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Andrei Popa
    July 27, 2017 at 1:05 pm
    If you already created the mask path on the lightning layer, you could duplicate it, put the duplicate over the original(in the timeline), delete the lightning effect(only from the duplicate) and set the original solid’s track matte to “Alpha inverted matte”.
    Andrei
