Activity › Forums › Maxon Cinema 4D › Mask a PLANE object — Boole or Spline Mask?
  • Mask a PLANE object — Boole or Spline Mask?
    Posted by David Jolosky on May 27, 2010 at 11:05 pm
    Thank you in advance for hopefully a simple solve. I’m working with a plane object that has PolyFX applied to it then a random effector (think mosaic effect) splitting the plane into many pieces. I’m hoping to make that plane into a shape other than a plane using a mask of some sort. I did have success putting an alpha channel mask in the texture of the plane but not exactly what I’d like, as I’d really like to use a spline mask and gradually move the shape mask into position over the plane.
    Making any sense? Masking a plane object with a boole or a spline mask rather than an alpha would be awesome.
    cheers and thank you.
    David Jolosky replied 16 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 28, 2010 at 8:32 pm
    I think the best way to do it is with the Bool object. The problem with spline mask is that it generates a new object every time you move one of the splines, so your pieces would be popping all over the place.
    But you can use a boolean object and it’s surprisingly spritely. The object order would be:
    Boolean Object (set to A subtract B)
    >Plane
    >>PolyFX
    >Cutting Object
  • David Jolosky
    June 1, 2010 at 8:28 pm
    Thanks Adam, I think I’m there. Worked well. It dawned on me with A subtract B that I need to create a reverse mask to contain my imagery within not without so I think this is the most efficient solve.
    cheers and thanks again.
    david
    david jolosky, visual communications || design || construct || interact
