Activity Forums Adobe After Effects Mask A Layer With Corner Pin Data
  • Mask A Layer With Corner Pin Data
    Posted by Milton Whitaker on December 16, 2011 at 3:37 am
    Hi guys. I have been beating my head against my desk all day trying to figure this one out. Maybe I’m crazy but I just can’t seem to get a handle on it. Here goes:
    I have some footage shot with a crane that is doing some pretty significant moves that I have successfully tracked using perspective corner pin. The footage contains a wall of squares, and each square needs light up with colors randomly. My goal is to use a single solid, create multiple masks on the solid, and animate the masks’ opacity. My problem is the corner pin data affects the masks so I can’t draw them precisely to fit the squares in the footage. I have tried precomping about 5 different ways but to no avail. What am I doing wrong?
    Any help is GREATLY appreciated! Thanks!
    MJ
    Roland R. kahlenberg replied 14 years, 9 months ago 3 Members · 2 Replies
  • Esky Ching
    December 16, 2011 at 11:17 am
    In that case, I would recommend you to render the layer with corner pin data out, in stead of precomp it. See if it works.
  • Roland R. kahlenberg
    December 16, 2011 at 1:03 pm
    First off, you should be using mocha. Secondly, post your video here so that we can have a look at the source footage.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
