Activity › Forums › Maxon Cinema 4D › Marvelous Designer 9 cloth is not smooth in C4D
  • Marvelous Designer 9 cloth is not smooth in C4D
    Posted by Rolands Zilvinskis on December 21, 2019 at 7:06 pm
    Hey,
    Anyone here familiar with Marvelous Designer? I’m using MD9 and I’ve ran into an issue. I’ve only used it for a very short time, so I’m not too familiar with it.
    Basically what happens is I create a simple garment in Marvelous and export it to C4D as either fbx or obj files and the garment never appears to be perfectly smooth. I’ve tried applying subdivision surface, cloth surface or smoothing deformer and most of the time these make it look far more worse. Every other tutorial I’ve watched about MD to C4D all they have done is apply a subdivision surface and the cloth becomes perfectly smooth, but in my case it always appears to be bumpy or rippled. I’ve also, of course, tried lowering the particle distance inside of Marvelous and it has had no affect.
    I’ve attached a screenshot so you get a better understanding of what I’m talking about. What am I missing here?
    Rolands Zilvinskis replied 6 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
