martin@romsdale.freeserve.co.uk
Posted by Martin Phillips on October 25, 2009 at 8:22 pmHi there
I need a quick question. If I apply a compressor fx to an audio track on a project, and copy and paste that project to a 2nd project 1. Will the audio fx be copied? 2. Will the fx effect other audio on the 2nd protect ?
MartinMike Kujbida replied 16 years, 10 months ago 3 Members · 9 Replies -
Mike Kujbida
October 25, 2009 at 8:37 pmAssuming you have Vegas Pro, you’d be better off nesting the first project into the second one.
That way you don’t have to worry about any FX from project #1 affecting anything in project #2. -
Martin Phillips
October 25, 2009 at 11:47 pmI assume nesting is where I drop the veg file of project 1 onto the timeline of project 2
regards
martin -
Mike Kujbida
October 26, 2009 at 12:57 amThat’s correct Martin.
Another advantage of nesting is that you can right-click the nested file and select “Edit in Vegas (*.veg)”.
This opens up the nested file in a new instance of Vegas allow you to make changes which, when saved, are immediately updated in the nested veg. -
Norman Willis
October 26, 2009 at 4:00 pmHi Mike.
As long as we are talking about nesting, may I please see if I understand how to nest?
To nest, I would:
1. open a second instance of Vegas, and then
2. select the things I want to nest from my first instance [either select all (CTRL-A) or select some (CTRL-click)], and then
3. copy (CTRL-C), and
4. paste (CTRL-V) onto a new video track in the second instance of Vegas?Thanks.
Norman Willis
http://www.nazareneisrael.org -
Mike Kujbida
October 26, 2009 at 6:14 pmNorman, nesting is importing the veg file of another project into the current one.
For example, the grade school graduation DVD I do each year is split into 5 sections.
I work on each section independent of each other and save them as separate veg files.
When it comes time to render the final project, I start a new project, import the 5 different veg files, drop them on the timeline and render as desired. -
Norman Willis
October 26, 2009 at 7:25 pm -
Mike Kujbida
October 26, 2009 at 7:31 pmYou import it, yes.
Be advised that 2 new filesare created (similar to the .sfk audio proxy files), one with a .sfap0 extension and one with a .sfap0.sfk extension, when you do this the first time. -
Mike Kujbida
October 26, 2009 at 7:32 pmI forgot to mention that a .sfap0 file is considerably larger than a .sfk file 🙁
