Marquee in a 1080/50i project
Havin problem with text in a roll.
Some letters merge with other letters. Usually
when I use capital letters.
My workaround is changing the kerning of one letter in a word.
Example:
I highligt the and give it a kerning of 0.70
The font is Arial Bold but this problem pretty much is there regardless of font.
The font size is 35.Any thoughts?
System:
HP workstation xw8200
2X Xeon CPU 3.40 GHz
3,50GB RAMWindows XP SP2
gfx card driver:
NIVIDA Quadro FX 1400
Driver version: 7.7.1.8Avid Media Composer v2.6.6:
from console:
MCBootstrap::gwhoami = 30
AVX Library V1.5
OpenGL implementation found:
vendor = Brian Paul
renderer = Mesa OffScreen16
version = 1.5 Mesa 6.4
This OpenGL implementation does not support hardware texture render
maximum render dimensions: = 1920 x 540 at 8 bits per pixel channelOpenGL implementation found:
vendor = NVIDIA Corporation
renderer = Quadro FX 1400/PCI/SSE2
version = 2.0.0
This OpenGL implementation supports hardware texture rendermaximum render dimensions: = 1920 x 540 at 8 bits per pixel channel
AvidQTURLManager – Checking version info for LoadLibrary AvidQTUpdaterVC7
AvidQTURLManager – AvidQTUpdaterVC7 Version (1.0) loading
AvidQTURLManager – loaded AvidQTUpdaterVC7 successfully
AvidSDMManager – Checking version info for LoadLibrary AvidSDM
AvidSDMManager – AvidSDM Version (1.11) loading
AvidSDMManager – loaded AvidSDM successfully
AWin32Mixer::Open inputMixerID = 0
Win32 Mixer is using SoundMAX Digital Audio, Version = 5.10
AlertableTimer Win32 constructor, default system clock resolution min = 1, max = 1000000
Media Drives:
Boot (C:), OSVolID = 67, 78140128 totalKB, 42182164 freeKB, 42099777 realFreeKB
Tight rope (G:), OSVolID = 71, 980462588 totalKB, 779057900 freeKB, 777536303 realFreeKB
Disksett 1 (H:), OSVolID = 72, 286743548 totalKB, 3979892 freeKB, 3972119 realFreeKB
Disksett 2 (I:), OSVolID = 73, 286743548 totalKB, 58308456 freeKB, 58194573 realFreeKB
COM1: error (2) The system cannot find the file specified.Dongle ID: EF55D31D
System ID: 4015379229
Avid Media Composer
Avid DVD Limited by Sonic
In Init ARO Cmds
The single frame player will be built for a length of 3600 frames
EmbedDNXCC turned off.
The default render wait time is 50
AAF DLL loaded from : C:\Program Files\Avid\Avid Media Composer\AAFCOAPI.dll
AAF DLL version : 1.1.3 (260) [0]——————————–
