Activity › Forums › Adobe Encore DVD › marque select bigger than button image causing overlap
  • marque select bigger than button image causing overlap
    Posted by Brian Gilmore on June 14, 2005 at 2:02 pm
    I created a menu and buttons in Photoshop .I have spaced out the buttons as I like them but when I import into Encore the marquee select is a bit bigger than the image .The result is that when I select the button it also selects some of the next button.I am tight for space so would prefer not to increase the spacing.
    Has anybody experienced this and do they have a solution
    cheers
    Brian
    Roadkill replied 21 years, 3 months ago 2 Members · 1 Reply
  • Roadkill
    June 14, 2005 at 2:07 pm
    The marquee encloses everything that is in the subpicture highlighting layer(s). If there are any stray pixels there, then these could cause it to be larger than expected.
