Activity Forums Apple Final Cut Pro Marking clips used in your edit?
  • Marking clips used in your edit?
    Posted by Peter Nowak on July 4, 2011 at 1:34 am
    How do you mark clips that you’ve used in your sequence?
    If you have many clips in your browser/media library and you want to clearly see which clips were already used, without looking through them and comparing?
    Even iMovie ’11 had that function – sections of clips that were used had an orange line through them. Is it possible to do in FCPX? Other then making them your favorites?
    Brendan Gibbons replied 15 years, 2 months ago 4 Members · 3 Replies
  • David Burch
    July 4, 2011 at 8:42 am
    You can see all the clips you are using in your sequence in a list view. Open up the drawer on the bottom right next to the film reel icon. It’s the same place you can view all your tags (markers) you’ve put into your project.
  • John Spirou
    July 4, 2011 at 9:33 am
    When i put an In Out point on a clip that i want to use it in my project i just assign a keyword (Used) in that (i assigned control + 1) and its easy to find all those clips.
  • Brendan Gibbons
    July 4, 2011 at 10:30 am
    Good tip this thanks.
    Only 1 extra keypress but will save a lot of pain towards the end of edit.
    cheers,
    Brendan
