Activity Forums Apple Final Cut Pro Legacy Marking clips in Final Cut 7
  • Marking clips in Final Cut 7
    Posted by Jamie Bianchini on January 13, 2013 at 11:48 pm
    I’m editing lots of long interviews and I need to mark various sections to go back and edit so I was thinking of using a marker on the clip itself. If i hit “M” it marks the timeline location but not on the clip itself. Is there a way to put markers so they show up on the actual clip? the “M” feature is fine but if i move the clip that marker does not move with it. Thanks!
    Jamie
    Matt Faw replied 13 years, 6 months ago 3 Members · 3 Replies
  • Shane Ross
    January 14, 2013 at 7:47 am
    If you want the marker to be on the clip, you need to load the clip into the VIEWER and watch it there.
    Shane
    Little Frog Post
  • Jamie Bianchini
    January 14, 2013 at 8:49 am
    Thanks, Shane. That should do the trick! Much appreciated!
    Jamie
  • Matt Faw
    March 15, 2013 at 6:24 pm
    Hi Jamie,
    You can also add the markers to the clip itself, while playing in the timeline, but the clip needs to be highlit first.
    Matt Faw
    Consciousness 3D
