Activity Forums Adobe Premiere Pro Marking All Clips 1 Frame
  • Marking All Clips 1 Frame
    Posted by Jamie Panton on May 22, 2015 at 3:06 pm
    Hi there,
    I have more a background in Avid Media Composer, however for my new job I am required to use Premiere. I’ve shot a few time-lapses over last few days. Usually I’d throw these into Avid and mark all them at once as having a 1 frame duration, then throw them all into a sequence. Is there a simple way to do this in Premiere?
    Jamie
    Jamie Panton replied 11 years, 4 months ago 3 Members · 3 Replies
  • Jeff Pulera
    May 22, 2015 at 8:22 pm
    Hi Jamie,
    Assuming you have one folder with all the sequentially-numbered stills in it, go to File > Import in Premiere, select FIRST of the stills, then check the box at bottom left of import window – I believe it says “Numbered Stills” or “Sequence” or whatever – and that will bring in the whole batch as a single CLIP to put in the Timeline.
    Jeff Pulera
    Safe Harbor Computers
  • Craig Howard
    May 23, 2015 at 4:42 am
    Another way..select all the clips in the BIN> Right Click> Speed Duration.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Adobe CC2014 Suite, Resolve
    Windows 7-64 bit:Assus P6T Deluxe Mob, 24 GB BM SDI Decklink, . HD Workflows
  • Jamie Panton
    May 23, 2015 at 10:20 am
    Great thanks both, will give both a go when I get back to the office! 🙂
