Activity Forums Adobe Premiere Pro Marking a Clip in Premiere
  • Marking a Clip in Premiere
    Posted by Josh Weiss on February 4, 2006 at 8:11 pm
    I am an experienced final cut user and am using premiere pro at home on my computer now. In final cut you can put the playhead over the clip you are interested in marking and hit x. This will mark the ins and outs for this clip for an easy insert edit. I can’t seem to find the button or shortcut for this in Premiere, though I’m sure its right in front of my face. Does anyone know what this button is?
    Josh Weiss replied 20 years, 6 months ago 6 Members · 13 Replies
  • 13 Replies
  • Alex Udell
    February 4, 2006 at 9:06 pm
    Click the Object (Clip or transition) and hit the / key.
    That should do it….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    See My Current Reel
    visit the combustion exchange ftp
  • Alex Udell
    February 4, 2006 at 9:08 pm
    If it helps…
    go to the edit menu and pull up the Keyboard Editor….
    They actually have an FCP preset…BUT..not all workflows are exactly the same…so you may still end up looking for things that Premiere doesn’t have or does differently enough that there may not be an equivalent in PPro.
    I use both….so just post if you need anything…
    Alex Udell
    See My Current Reel
  • Craig Howard
    February 4, 2006 at 10:16 pm
    In PremPro you put a “Marker” on a clip or the timeline using the asterisk key from the Number Keypad.
    In and out points use the short cut keys “I” and “O” respectively
  • Alex Udell
    February 4, 2006 at 10:28 pm
    Hi Craig…
    What he means is to mark the clips I to O duration….
    so select the clip and hit /
    this will place the In and Out marks on the TL…
    Alex Udell
    See My Current Reel
  • Josh Weiss
    February 4, 2006 at 11:27 pm
    Yeah, that did it. The hardest part was finding that in the menus. There’s no way to search, so at least knowing the / shortcut I could then find it and change it to X as in final cut. Thanks a lot guys.
  • Bon Sawyer
    February 5, 2006 at 1:07 am
    Is there another shortcut to select the clip (under the timeline cursor) prior to marking it, without having to use the mouse?
    Cheers,
    Bon
  • Alex Udell
    February 5, 2006 at 7:16 pm
    I have learned to accept the fact that it is difficult to escape the mouse in PPro..
    You just need to use it…
    Alex Udell
    See My Current Reel
  • Steven L. gotz
    February 5, 2006 at 7:26 pm
    Said in a distant voice:
    “Use the mouse, Luke!”
    Steven
    http://www.stevengotz.com
  • Craig Howard
    February 5, 2006 at 7:49 pm
    How do the other NLEs know which clip to select from the CTI position in the case of multiple video tracks where clips may overlap?
  • Josh Weiss
    February 5, 2006 at 10:01 pm
    In Final cut there are selections for which video track is active. So if for instance you want to do an insert edit on an audio track that thinks it should go on 1 and 2 you can move these markers to 3 and 4 and the clip will insert to that track. So when you mark a clip without the mouse, it will mark video one as the default track first if it is active, if you make in not active it will go to video 2 and so on. You can make only one track active so you don’t have to fumble around with it too much. Its a nice system.
