Activity Forums VEGAS Pro Markers with DVD Architect
  • Markers with DVD Architect
    Posted by Richard Swain on January 4, 2007 at 7:33 pm
    Hi All,
    I am using Vegas 7 and DVD Architect 4. I my project to an .MPG file. My project has markers, and I have set the flag to include markers in the output file. Everything is rendered OK (I also render the audio to an .MP3 file). When I load the rendered file into DVD Architect I don’t get the chapter markers. Also, the button to load markers is grayed out. Any ideas about what is going on?
    Richard
    Basket Cat Productions
    Richard Swain replied 19 years, 7 months ago 2 Members · 4 Replies
  • Edward Troxel
    January 4, 2007 at 8:10 pm
    Did you move the file?
    Also, you should render the audio to AC3 – not MP3.
    Edward Troxel
    JETDV Scripts
  • Richard Swain
    January 4, 2007 at 8:47 pm
    Hi Edward,
    Yes, I moved the file from one computer to another (I edit on one (the faster) and burn on another). Ihave read a few posts, and discovered that I should be rendering the audio as an .AC3 file – will do in the future.
    Richard
  • Edward Troxel
    January 4, 2007 at 8:57 pm
    When you moved the file, you lost the markers. The marker information is stored in a separate file (maybe a .sfl???). You would also need to move that file. Even then, I’m not sure it would be automatically picked up.
    Edward Troxel
    JETDV Scripts
  • Richard Swain
    January 4, 2007 at 9:54 pm
    Hi Edward,
    That did the trick – I moved the .mpg.sfl file over to my DVD PC and everything worked fine. In the past i had rendered to .AVI files, and the markers are actually in the file. Thanks for the help!
    Richard
