Activity Forums Adobe After Effects Markers triggers layers
  • Filip Vandueren
    February 27, 2023 at 12:25 pm
    Although it may need some extra logic if two consecutive markers have the same name, which they don’t in your example… Something like this:
    m = thisComp.marker;
    nk = m.nearestKey(time);
    pki = nk.index - (nk.time > time && nk.index>1 ? 1: 0);
    k = m.key(pki);
    if (k.comment==thisLayer.name) {
    linear(time,k.time,k.time+1,0,100);
    } else if (pki>1 && m.key(pki-1).comment==thisLayer.name) {
    linear(time,k.time,k.time+1,100,0);
    } else {
    0;
  • Jean Livenais
    March 1, 2023 at 4:18 pm
    Thank you Filip, it works great.
    Is there a way to start the transition before and end the transition after each marker, so that the marker is half way of each transition?
    I tried to modify the code but it didn’t turn as wished.
  • Filip Vandueren
    March 1, 2023 at 9:08 pm
    I think you only need to change line 2 into nk = m.nearestKey(time+0.5) ; but I haven’t tested.
  • Jean Livenais
    March 3, 2023 at 8:14 pm
    I tried and the transition stay the same.
    Maybe with some negative value with the posterize function.
