Activity › Forums › Adobe Premiere Pro › Markers that move with clip
  • Markers that move with clip
    Posted by Tom Seery on May 9, 2009 at 4:06 am
    Is there a way to set markers to follow a clip as it is moved in the timeline? This would be very helpful since I am editing the same event but from two different cameras that are not in synch and have to do a lot of fine tuning. Let me know.
    Thanks Guys!
    Tom
    Tom Seery replied 17 years, 4 months ago 3 Members · 3 Replies
  • Eddie Lotter
    May 9, 2009 at 4:02 pm
    Use “clip markers” to have markers that stay with the clip. All other markers are sequence markers that stay where they are in the sequence.
    It’s worth noting that if you nest a sequence in another sequence then the nested sequence’s markers work like clip markers.
    Cheers
    Eddie
  • Alex Udell
    May 9, 2009 at 7:27 pm
    If the clip is already on the timeline, then double click it to load it into the source viewer.
    Navigate to where you want a marker and hit the * key on the keypad to add a non numbered marker.
    Alex
  • Tom Seery
    May 17, 2009 at 4:52 am
    Thanks Guys!
