Activity › Forums › Adobe Premiere Pro › Markers on the timeline
  • Markers on the timeline
    Posted by Colin Burwell on March 21, 2008 at 11:10 pm
    I’m editing a lot of different interviews on one timeline. After a few hours of chopping and rearranging, I start to lose track of which group of clips on the timeline are which.
    Is there a way to place markers on the timeline that I can input a few words to give me a visual cue as to what the content of each group is?
    Jon Barrie replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jon Barrie
    March 22, 2008 at 6:25 am
    Personally I would edit the interviews with a sequence for each then I could just switch timeline tabs to get the footage I want.
    But to answer your question. Yes. You can set a marker in the timeline with the * (asterix) in the num pad and while still on it hit the * (asterix) in the num pad again to open the marker properties, you can make notes there then use the next back buttons to skip to a fro of other markers. You can also double click a marker on the timeline to open the properties box.
    – Jon 🙂
    How many editors does it take to change a light bulb?
