Activity Forums Adobe Premiere Pro Markers in the timeline.
  • Markers in the timeline.
    Posted by Terry Lyons on November 12, 2011 at 1:18 pm
    Are there shortcut keys to move around markers and to delete them or must I make my own? Help.Adobe.com says this:
    “To cue the current-time indicator to a clip marker, select the clip in the sequence and choose Marker > Go To Clip Marker” (or “Go To Sequence Marker”)
    Well, if my mouse is on the clip then I can just press Shift and click on the marker and not wasted time traveling through the Marker menu system.
    But there HAS to be a shortcut key Help.Adobe.com is secretly hiding, right?
    Terry Lyons replied 14 years, 10 months ago 2 Members · 2 Replies
  • Alex Udell
    November 14, 2011 at 2:52 pm
    yes there are shortcuts…..
    But the clip has to at least be selected in the timeline or they don’t work.
    They should be listed in the menu.
    Also…
    PPRO differentiates between clip keyframes navigation and sequence keyframe navigation with different sets of hot keys.
    Thanks…
    Alex
  • Terry Lyons
    November 14, 2011 at 3:25 pm
    Thank you!
