Activity Forums Adobe After Effects Markers in multiple nested comps?
  • Markers in multiple nested comps?
    Posted by Balazs Frank on August 10, 2010 at 7:53 pm
    I am using multiple nested compositions, all elements synced to the main soundtrack.
    The problem is that after nesting I do not see the original audio markers (neitther from the audio comp, nor from the main comp) and the only solution I have is to copy the layer marker tracks every time deep inside the structure to follow the timing.
    Is there any easier way to see the marker track always, independently of which item in the nested structure I work on?
    thanks,
    B.
    Balazs Frank replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
