Activity Forums Adobe Premiere Pro markers in cs5
  • markers in cs5
    Posted by Yotam Monk on September 10, 2011 at 12:41 am
    hi guys!
    funny question…,im editing music videos in premier for a long time now…,im using the * key to add markers to the time line to mark the beat of music,the problem is that when i move the clip(the audio) i loose the mark,is there a way to mark the clip and not the time line?
    there must be a way…cs5 by the way
    cheers!
    yotam
    Yotam Monk replied 15 years ago 3 Members · 4 Replies
  • Derek Andonian
    September 10, 2011 at 3:25 am
    You can set a clip marker by selecting the clip and going to the “marker” menu and select SET CLIP MARKER -> UNNUMBERED. By default there’s no shortcut key for this, but you can create one in “Keyboard Customization” in the EDIT menu.
    Another thing you could try is set sequence markers like you’ve been doing, then when you’re done marking beats, nest the sequence into a new sequence- then all the sequence markers will become clip markers in the nested clip.
    ______________________________________________
    “THAT’S our fail-safe point. Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
  • Ann Bens
    September 10, 2011 at 12:51 pm
    You can put the markers on the music clip by opening the clip from the timeline or Project Panel in the Source Monitor and adding the clip markers by using the * key.
    Adobe Certified Expert Premiere Pro
  • Yotam Monk
    September 10, 2011 at 1:13 pm
    thank you!
  • Yotam Monk
    September 10, 2011 at 1:14 pm
    thank you!
