Activity Forums Adobe After Effects markers for audio
  • markers for audio
    Posted by Lisa Simonson on September 1, 2011 at 1:41 am
    I need to sinc audio to animation. Is there a way to hear audio frame by frame? I need to place lots of little markers in the time line and having a hard time doing it by looking at the wave form. Thanks!
    Ben G unguren replied 15 years ago 3 Members · 3 Replies
  • Ben G unguren
    September 1, 2011 at 2:31 am
    Hold the command/ctrl key down while dragging the timeline around and you’ll hear samples of the sound at the current time.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Brian Charles
    September 1, 2011 at 4:42 am
    Press the period key on the numeric keypad, this will play the audio without rendering any animation.
    Use the asterisk key on the numeric keypad while the sound previews to place markers for your cue points.
    If you’re using a laptop without a numeric keypad, the keyboard shortcuts are listed under Composition > Preview and Layer > Add Marker.
  • Ben G unguren
    September 1, 2011 at 2:33 pm
    Note that the asterisk key adds a marker to selected layers only. I will often put in a layer, turn off its visibility, and use is exclusively for layer markers. You might even want more than one layer for this is you’re trying to sync multiple elements….
    Ben Unguren
