Activity › Forums › VEGAS Pro › Markers / DVDA
  • Markers / DVDA
    Posted by Stewart Bourke on June 19, 2010 at 7:31 am
    I am looking for some help (again) with markers.
    I simply cannot get markers to appear in DVDA unless I take the ‘single movie option’
    Been using VMS9 for about two years now, and recently moved to VMS10. Every single file I render does exactly the same thing.
    1. Render a project, setting ‘include project markers’
    2. I go into DVDA, choose ‘new project’, then select ‘menu based’
    3. Drag my mpg file onto the timeline – both the mpg and ac3 appear fine – but – there are no markers showing, and the buttons to insert a marker, load markers from file and save markers to file are greyed out
    4. I start a new project, choose ‘menu based’, select the same mpg and it imports, with all markers, and all buttons available.
    5. I then add a scene selection menu and it picks up all the markers.
    Whilst I know I can get around this issue it is driving me mad, as it should work. I believe I have looked through all settings/preferences etc, and the .sfl is in the same directory but I cannot find anything that would make this difference…
    Would anybody have any suggestions (or have come across this behavior)
    Stewart Bourke
    John Rofrano replied 16 years, 3 months ago 2 Members · 3 Replies
  • John Rofrano
    June 19, 2010 at 2:35 pm
    After you drag your MPG file into the menu, double-click on it and that should load it onto the DVDA timeline. If the markers aren’t seen, the buttons should now be available to import them.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stewart Bourke
    June 20, 2010 at 10:08 pm
    That was one of those moments when you kick yourself…
    I have only ever dragged the media directly to the timeline, and it never showed me the markers. I thought I had tried everything, but clearly not – never even thought of trying the dragging onto the treeview.. Thanks for the info…
  • John Rofrano
    June 21, 2010 at 11:52 am
    You’re welcome. Glad that fixed it.
    ~jr
