Activity Forums Apple Motion Markers
  • Markers
    Posted by Praveen Nu on January 9, 2013 at 12:25 pm
    Hi all,
    I have created on animation in Motion which has an “in” motion, then loop, then “out”.Added the markers also. But loop and build out marker is not working at the same time if build in is there.Any solution?..It should play build in then loop(n times) then build out..
    Pls help me.
    Thank you,
    Praveen N U
    http://www.nupraveen.com
    Mark Spencer replied 13 years, 7 months ago 2 Members · 1 Reply
  • Mark Spencer
    January 9, 2013 at 1:37 pm
    It doesn’t work that way. You have to choose. Either Build In/Out (one or both) or Loop. Can’t have a loop marker together with Build In or Out.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
