Activity › Forums › Adobe Premiere Pro › marker visibility in source window
  • marker visibility in source window
    Posted by Zelda Greenstein on August 14, 2016 at 2:35 pm
    Is there any way to change to look of the marker description that appears in the source window. The default is tiny black letters against a dark blue highlight. Which is nearly impossible to read if the frame is dark. Is there any way to resize the font and/or change the color of the font and highlight. It is almost useless because I can’t read it. And in the markers window I only see the first 18 characters so I can’t read it there, only if I put the marker name in the comment column which is not limited.
    The color coding is great and I use markers extensively when I log.
    Any suggestions.
    thanks
    Zelda Greenstein replied 10 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
