Activity Forums Adobe After Effects Expressions marker trigger 3d rotation
  • marker trigger 3d rotation
    Posted by Guillaume Charron on August 25, 2009 at 2:58 pm
    I was using this expression to animate in a text layer on the X rotation (3D):
    veloc = 7;
    amplitude = 80;
    decay = .7;
    amplitude*Math.sin(veloc*time)/Math.exp(decay*time)
    To make it start when I wanted, I had to precomp it (because it uses the time of the comp). So I found another expression to trigger the expression with a marker:
    if (marker.numKeys > 0 && time >= marker.key(1).time){
    t = time – marker.key(1).time;
    freq = 2.0; //oscillations per second
    amplitude = 90;
    decay = 1.5;
    rotCos = Math.abs(Math.cos(freq*t*2*Math.PI));
    x = amplitude*rotCos/Math.exp(decay*t);
    value – [x]
    }else{
    value
    It works but it is not swinging in both directions. It bounced on the 0 value and swing back up.
    Can you help me make it swing correctly using a marker as a trigger?
    thanks.
    Guillaume Charron replied 17 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 25, 2009 at 6:35 pm
    Try this:
    veloc = 7;
    amplitude = 80;
    decay = .7;
    amplitude*Math.sin(veloc*t)/Math.exp(decay*t)
    }else{
    value
    Dan
  • Guillaume Charron
    August 25, 2009 at 8:34 pm
    I knew it was something like that. I tried to find it myself but it didn’t work. THANK YOU very much. 🙂
