Activity › Forums › VEGAS Pro › Marker that sticks
  • Marker that sticks
    Posted by Roger Bansemer on April 29, 2013 at 7:11 pm
    I need my markers to move as I slide events around but is there a way to lock a marker that always stays in place and still let the rest move with events?
    I’d like to know at a glance where the end of my project falls. I have created a track and have put a long text file on it that says END and I lock that event in place so I can see where the end of the show is suppose to fall but the track is not always in view as I work the timeline.
    Roger Bansemer – PaintingAndTravel.com
    Roger Bansemer replied 13 years, 5 months ago 3 Members · 3 Replies
  • Graham Bernard
    April 30, 2013 at 7:49 am
    [Roger Bansemer] ” is there a way to lock a marker that always stays in place and still let the rest move with events?”
    No.
    [Roger Bansemer] ” . . . so I can see where the end of the show is suppose to fall but the track is not always in view as I work the timeline.”
    So, you want a “graphical” representation ON your Timeline that will ALWAYS be in view? Yes? What I am offering you is NOT what this function is originally meant for, but try this:-
    On the Toolbar Go to:-
    1] View > Video Bus Track – Select
    2] Insert MUTE Envelope
    3] At the Program END apply a POINT and MUTE the Envelope by pulling it down.
    Result?
    A] What you can see in the Video Bus Track AFTER that Mute will be “greyed-out” – visually WARNING you you’ve reached the END of your Project.
    PLUS
    B] As you Roll your Tracks UP or DOWN that Video Bus and as you approach that MUTE, or here, your PROJECT END, it will ALWAYS be revealed.
    Cheers
    Grazie
  • Stephen Mann
    May 1, 2013 at 4:22 am
    Wow, that’s a cool workaround. It isn’t as convenient as an event marker, but it’s close.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Roger Bansemer
    May 2, 2013 at 11:39 am
    Hi Graham,
    That’s a great suggestion. Works for just what I want.
    Been busy editing two new shows.
    Thanks Graham.
