Activity Forums Adobe After Effects Expressions marker.numKeys works sometimes, sometimes not
  • marker.numKeys works sometimes, sometimes not
    Posted by Anders Hattne on October 31, 2024 at 10:19 am
    Hello, I’ve got this expression to display the layer’s marker comments. The expression works most of the time, and other times it works but displays an error message. I get a message saying the property has no keyframe(s).
    What can I do to make it consistently work?
    s = thisComp.layer(“Notes”);
    v = “”; // variable for comment output
    k =1; // here I store my marker keyframe number. I put 1 to see if it works better than 0
    if (s.marker.numKeys > 0) {
    k = s.marker.nearestKey(time).index;
    if (time < s.marker.key(k).time) k–; // this to make the keynumber look backwards
    v = s.marker.key(k).comment;
    // here I get an error saying the property has no keyframe 0 !!!
    else {v = ” “}
    v
    Ming Hsu replied 1 year, 10 months ago 4 Members · 5 Replies
  • Yoan Boisjoli
    October 31, 2024 at 11:19 am
    I think the error occurs because the expression sometimes sets the key index to 0, and After Effects keyframes start at 1, making index 0 invalid.
    Try something like this:
    s = thisComp.layer("Notes");
    v = ""; // Variable for comment output
    // Check if the current time is before the nearest key's time
    if (time < s.marker.key(k).time) {
    k--; // Decrement k to get the previous key
    // Ensure k does not go below 1
    if (k < 1) {
    v = ""; // Optionally, set to a default value if no previous key exists
    } else {
    } else {
    } else {
    v = " "; // Default value if there are no markers
    v
  • Anders Hattne
    October 31, 2024 at 11:53 am
    Ah, I think I understand. Not sure what the term is but most properties seem to start counting at 0. Keyframes start at 1?
    I’ll have a closer look thanks. Using k– with nearestKey was a breakthrough for me 🙂 Finally got over that hurdle!
  • Yoan Boisjoli
    October 31, 2024 at 12:16 pm
    Yeah! After Effects’ keyframe indices start at 1. This means the first keyframe is key(1), the second is key(2), and so on !
  • Dan Ebberts
    October 31, 2024 at 3:52 pm
    You can minimize the code a little like this:
    m = thisComp.layer("Notes").marker;
    v = "";
    if (m.numKeys > 0){
    k = m.nearestKey(time).index;
    if (time < m.key(k).time) k--;
    if (k > 0) v = m.key(k).comment;
    v
  • Ming Hsu
    November 1, 2024 at 2:01 am
    m = thisComp.layer(“Shape Layer 1”);
    txt = “”;
    if (m.marker.numKeys > 0){
    n = m.marker.nearestKey(time).index;
    if (time < m.marker.key(n).time) n–;
    if (n > 0) txt = m.marker.key(n).comment;
    txt
    Maybe you can try this 🙂
