Activity Forums VEGAS Pro Marker Numbers in Sony Vegas Pro 9
  • Marker Numbers in Sony Vegas Pro 9
    Posted by Rex Polanis on January 28, 2011 at 12:00 am
    I am trying to figure this out. I am editing a project that I previously added markers to. Now I need to add new markers between the old ones I already have. The problem is that whenever I add a new marker, say between existing markers 3 and 4 (and I have a total of 25 markers) the new marker between 3 and 4 will be 26.
    How do I make it so that if I want to add a new marker all the other markers will change to reflect the new marker. For example, I add a new marker between markers 3 and 4, and the new marker becomes 4 and all the following markers change sequentially. I use an audio editor (Sonar 7 Producer) that automatically changes all the post markers. Can this be done in Sony Vegas Pro 9?
    Thank you for your time.
    Rex Polanis replied 15 years, 7 months ago 2 Members · 2 Replies
  • John Rofrano
    January 28, 2011 at 12:24 am
    As you have seen, Vegas doesn’t do this automatically. What you have to do is open View | Edit Details, select show Markers and highlight the upper left corner and use Ctrl+C to copy. Then select all of the markers in your project and delete them. Finally, paste them back into Edit Details and they will get renumbered.
    You can also use a script to do this. VASST Ultimate S Lite and Ultimate S Pro have this capability.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rex Polanis
    January 28, 2011 at 12:45 am
    thank you!!!
