Activity Forums Adobe After Effects Expressions Marker index for layer index
  • Marker index for layer index
    Posted by Ilya Sire on September 19, 2017 at 2:52 pm
    Hello forum,
    Here is the situation. How can i scale in and out like this?
    i have 10 comp markers.
    and i have 5 layer to zScale.
    layer 1: zScale from 100 to 150 (1st marker) and from 150 to 100 (2nd marker)
    layer 2: zScale from 100 to 150 (2nd marker) and from150 to 100 (3rd marker)
    … i attach the aep sample how it look like.
    11698_popupscalecopycc12.aep.zip
    thank you~~
    Ilya Sire replied 8 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 19, 2017 at 5:16 pm
    This should get you started. If you simplify things by making layer 1 the top-most layer in the layer stack (and layer 5 the bottom-most) and add a 6th comp marker to trigger the out ramp of layer 5, you could use something like this:
    m = thisComp.marker;
    tRamp = 1;
    val = value;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (time < m.key(n).time)n--;
    if (n == index){
    t = time - m.key(n).time;
    val = linear(t,0,tRamp,[100,100],[150,150]);
    }else if (n == (index+1)){
    val = linear(t,0,tRamp,[150,150],[100,100]);
    val
    Dan
  • Ilya Sire
    September 19, 2017 at 6:16 pm
    Yes, it worked. I forgot that. This is right. 1st layer top, last layer bottom.
    Thank you a lot for helping me Sir
    ilya
