Activity Forums Adobe After Effects Expressions Marker comment to text in one line
  • Marker comment to text in one line
    Posted by Otávio Nascimento on September 8, 2022 at 7:59 pm
    Hey, I have a expression that copy comments from markers and add to text.
    But I want all the texts in one line. How do I do it?
    n = 0;
    t = 0;
    x = text.sourceText;
    if (marker.numKeys > 0){n = marker.nearestKey(time).index;
    if (marker.key(n).time > time) n–;}
    if (n > 0)
    marker.key(n).comment; else ”;
    I tried adding: replace(/\r/g, ”) at end of expression but didn’t work.
    Dan Ebberts
    replied 4 years ago
    2 Members · 5 Replies
  • Dan Ebberts
    September 8, 2022 at 8:29 pm
    I’m not sure what you’re asking exactly, but maybe like this:
    txt = "";
    for (i = 1; i <= marker.numKeys; i++){
    txt += marker.key(i).comment;
    txt
  • Otávio Nascimento
    September 8, 2022 at 9:24 pm
    I want to remove from all comments the “enter to another line” so the text stays in one single line. So I can adjust the lines with the paragraph text.
  • Dan Ebberts
    September 8, 2022 at 9:46 pm
    That’s interesting. Apparently, carriage returns in marker comments have both carriage return and line feed characters. Try this:
    txt = "";
    if (time < marker.key(n).time) n--;
    if (n > 0){
    txt = marker.key(n).comment.replace(/\r/g, "").replace(/\n/g, " ");
    txt
  • Otávio Nascimento
    September 8, 2022 at 10:29 pm
    Thank you! It worked, but if I want to edit one comment and add another line. Is it possible?
  • Dan Ebberts
    September 9, 2022 at 5:38 am
    I think so. It seems to work for me (but I may not understand what you’re asking).
