Activity Forums VEGAS Pro marker attached to audio clip
  • marker attached to audio clip
    Posted by Jeffree Charles on May 19, 2020 at 1:15 pm
    I got this audio file online and surprisingly it had several markers attached to the clip. Does this work for video clips too? If so, how do I add multiple markers which are attached to clips (not timeline, not snap offset) and moves with the clip whenever the clip is repositioned? In my situation, the markers attached to this audio clip cannot be moved nor renamed though. I would expect vegas pro to support this feature by the way they displayed this audio clip.
    Jeffree Charles replied 6 years, 3 months ago 3 Members · 4 Replies
  • Francois Pénzes
    May 19, 2020 at 2:54 pm
    Hi jeffree
    You insert those markers via the Trimmer Window. You then save your markers and then create the sub-clip.
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Francois Pénzes
    May 19, 2020 at 3:15 pm
    Me again
    Here’s a breakdown of the Trimmer window. A little dated but still relevant.
    https://vegaspro.helpmax.net/en/the-vegas-window/window-docking-area-and-floating-window-docks/trimmer/
    Cheers !
    Radeon RX 5700 XT
  • Dimitrios Papadimitriou
    May 19, 2020 at 4:09 pm
    it also means some edited or at least inserted markers into the file for his own reference then rendered it and you downloaded it. I wanna say theres an option to disallow that from being applied to your renders or not.
  • Jeffree Charles
    June 1, 2020 at 8:42 pm
    Thanks for the info! I never knew subclips existed. I’ll definitely have a look at it. Thanks again.
