Activity Forums Adobe Encore DVD marker accuracy problem with m2v file
  • marker accuracy problem with m2v file
    Posted by Alain Pire on March 13, 2013 at 2:55 pm
    I made a live musical film and I want to transcode it onto DVD.
    I used FCPX and I exported it to a .mov file (166Gb) – put it into Encore, set my markers …and everything went fine.
    But after checking the video quality on a TV screen, I decided to try to improve it, so I sent the .mov file into Compressor 4 and got a m2v file.
    Back into Encore, I cannot set my markers precisely, it leaves a gap between timeline bars and I cannot set it precisely where I want, which is annoying because I need markers to start right a the beginning of a song.
    Alain
    Alain Pire replied 13 years, 6 months ago 2 Members · 2 Replies
  • Roel Bus
    March 14, 2013 at 2:58 pm
    Hi Alain,
    m2v files are long GOP files, with (depending on your settings, but the default is) an i-frame every 15 frames. That means twice a second. The rest of the frames are interpretive, either forwards or backwards. They do not contain all the information like the i-frames do.
    After encoding, Encore does not let you put a marker on anything other than an i-frame, so you can’t do frame accurate marking anymore.
    That’s one reason why markers can not be put where you want it.
    Hope this helps,
    Roel
  • Alain Pire
    March 14, 2013 at 3:28 pm
    Thanks Roel,
    So I think that I’ll stick to my original uncompressed .mov file which allows me to put markers on a frame basis
    Alain
