Activity Forums Adobe After Effects marked road on a map
  • marked road on a map
    Posted by Helmuth E. guenther on February 7, 2007 at 4:04 pm
    On a map I like to mark a road with a red line (7 pixels wide) starting at point “A” following the road and stopping at point “B”. The composition should last about 10 seconds.
    If possible it will stop at about the middel of the distance and wait 1 second before it will proceed.
    I appreciate any help!
    Best Regards
    Helmuth
    Mike Clasby replied 19 years, 6 months ago 4 Members · 6 Replies
  • Julian Sixx
    February 7, 2007 at 4:13 pm
  • Mark
    February 7, 2007 at 4:21 pm
    1. Draw a spline on the layer (or a solid) using the pen tool.
    2. Add the Stroke effect and select the mask layer as the spline you created.
    3. Animate the start or end…..
    4. If the stroke effect is on same layer as map select on original, if on solid layer, select on transparent (this is a small pulldown menu on bottom of filter).
    Regards
    Mark
  • Helmuth E. guenther
    February 7, 2007 at 4:46 pm
    Thank you very much!
    Done!
    Helmuth
  • Mike Clasby
    February 7, 2007 at 6:34 pm
    Julian, great link. How did you find that? I recognize Rick Gerard’s voice but have never seen that source. Is there other tuts there, I can’t get an others by manipulating the url?
  • Julian Sixx
    February 7, 2007 at 9:15 pm
    Hi
    [yikesmikes] ” How did you find that?”
    I’m not sure but i think i found it in the Cow archives.
    https://www.adobe.com/special/aftereffects/tips/
    [yikesmikes] “I recognize Rick Gerard’s voice”
    I think it’s Brian Maffitt’s voice
  • Mike Clasby
    February 7, 2007 at 9:26 pm
    I do believe your right.
