Activity Forums Apple Final Cut Pro Legacy mark audio peak F.A.B.
  • mark audio peak F.A.B.
    Posted by Ken Pugh on March 13, 2007 at 2:47 pm
    Just started using this tool – wish I’d been doing it before – fantastic! Extremely accurate at detecting only those peaks that exceed 6 on my external PPM metre, amazing (must have my audio set-up lined up nicely). I’m most impressed with how it takes into account the clips volume level. My only dissapointment, having to use the mark audio peak command on each individual clip on the timeline. You can select multiple clips from the browser – but this doesn’t help as the programme does not then know the volume applied in the timeline. Does anyone know if it’s possible to select multiple clips in the timeline?
    Ken.
    (LINE UP -24db = 4PPM peaks 8db above at 6PPM)
    Ken Pugh replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
