Activity Forums VEGAS Pro Mark All tracks from Current timeline position to End of Timeline (simple method?)
  • Mark All tracks from Current timeline position to End of Timeline (simple method?)
    Posted by Tobias Hame on February 6, 2006 at 5:29 pm
    As you can read in the subject, my question is if there is a simple method to
    mark all clips on all tracks from the current timeline position to end of the timeline. this I have to do quite often, and I guess I am not the only one.
    My current method is to zoom out to see the whole project timeline, change to “Selection Edit Tool” and mark with the ‘rectangle marking method’ all of the clips. Then i zoom in again and change to “normal edit tool”
    Since I would like not to do this zooming, is there a more simple/fast method?
    thanks,
    paralion
    Tobias Hame replied 20 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Terry Esslinger
    February 6, 2006 at 6:14 pm
    Either Ultimate S or Excaliber has this function that works quite quickly and simply. I am not at my editor and cannot remember which one has it (I have both). I use it alot.
  • Tobias Hame
    February 6, 2006 at 6:43 pm
    would be great if you could find out which function this is. that is to say, how it can be done.
    PS: strange actually that sony hasn’t integrated this thing. I guess every editor needs to do this quite often…
    thanks,
    paralion
  • Gilles Pialat
    February 6, 2006 at 6:46 pm
    Try Ctrl+Shift+End (or Ctrl+Shift+Home)
  • Edward Troxel
    February 6, 2006 at 7:07 pm
    I use the Select Events tool in Excalibur. Ultimate S has a similar function. Scripting is definitely the way to go for this task. I have the “Select Events” button on my toolbar so all I have to do is push a button and I’m done!
    Edward Troxel
    JETDV Scripts
  • Gary Kleiner
    February 6, 2006 at 7:10 pm
    I assume that you are needing to select the events.
    Why do you need to do this? If it is to move the events en masse, then you can use the ripple mode without needing to select events.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Terry Esslinger
    February 6, 2006 at 7:38 pm
    This ability is in Excalibur “select events” All events under curser and beyond and on selected lines.
  • Tobias Hame
    February 18, 2006 at 9:19 am
    I have to admit that i seem not to be smart enough to solve this problem by using the trimmer, i prefer to select all the events. Now I got Ultimate S, still I didn’t figure out which function is the one I am searching for.
    Can anybody help?
    Thanks in advance,
    paralion
