Activity › Forums › Adobe After Effects Expressions › Mario style camera
  • Mario style camera
    Posted by Flitch13 on May 3, 2007 at 6:21 pm
    Hi all!
    I am making a mario style animation where the camera keeps the subject in the center of the frame while he is going forward, but stops when he goes backwards.
    I can get the camera to follow no problem when he goes forward by linking the x position properties. My problem comes when I try to determine whether he is going forwards or backwards.
    Any help would be appriciated!
    Thanks.
    Flitch13 replied 19 years, 5 months ago 3 Members · 4 Replies
  • Kerryt
    May 3, 2007 at 7:40 pm
    you could try something like this.
    at the start of the script set x_max=x
    then in the update part you put this
    if x > x_max
    then xmax =x
    then link the camera to xmax not x
    that way x_max contains only positive and greater values of x, eg when x declines the camera stays at x_max
    hope that helps
    Kerry.
  • Flitch13
    May 3, 2007 at 8:11 pm
    thanks for the response. I sort of get the idea behind it, but am having trouble actually implementing it. I’m really new to expressions, so maybe if you could show me a sample code that would help a lot.
  • Filip Vandueren
    May 3, 2007 at 10:23 pm
    This works for me:
    expression for the camera’s position
    marioPos=thisComp.layer("mario").transform.position;
    progress=valueAtTime(0)[0];
    f=thisComp.frameDuration;
    for (t=0;t<=time;t+=f) { progress=Math.max(progress,marioPos.valueAtTime(t)[0]) } [progress,value[1],value[2]]
    as with many occasions a loop is needed that checks all the positions 'Mario' has been in since time=0
  • Flitch13
    May 4, 2007 at 1:38 am
    thanks! that worked perfectly
