Activity › Forums › Adobe After Effects › Margin or orientation of text
  • Margin or orientation of text
    Posted by Peter Parker on November 29, 2015 at 9:29 pm
    Hi guys , first of all I have to admit that I am new to After Effects and that I have been playing with the interface for the last weeks.
    In general when I work in any text editor (like notepad) I usually type the text and it goes from left to right , leaving the initial text on the position it was before.To illustrate what I mean :
    Photoshop behaves as expected :
    Now , when I go to after effects , this is what happens :
    As you can see , as I type the text moves to the left instead of moving to the right as most text editors do.
    If it helps , this is the configuration of my text layer :
    In general I don´t know how to explain well the problem in technical words , but that’s basically what happens. If I paste a text in that layer,I need to move the text back to it’s initial position.
    I would like to be able to create some sort of margin to avoid this to happen.
    Peter Parker replied 10 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
