Activity › Forums › Adobe After Effects Expressions › mapping video frames to layers
  • mapping video frames to layers
    Posted by Ted Intorcio on January 31, 2013 at 7:39 pm
    I’m trying to create an old fashioned- flip book animation from a mov file. where each card that I flip into place has the next frame of video displayed on it. So if I have a 10 frame movie clip (quicktime or Tiff sequence) I assume a slider would be involved and some sort of frame to time code? Not really sure. Any help would be most appreciated! BTW i have the cards working in space through expressions I just need to map a frame to each layer now. Thanks!
    -Ted
    Ted Intorcio replied 13 years, 7 months ago 2 Members · 4 Replies
  • Ted Intorcio
    January 31, 2013 at 8:11 pm
    I should mention that the reason I’m doing it with expressions is to easily replace video clips and to be able to vary the speed of the flips for different animations. Thanks again
    -Ted
  • Ted Intorcio
    January 31, 2013 at 8:48 pm
    I found this piece of code to be very helpful
    //.0417 is the decimal time for 23.976fps video
    thisComp.layer(thisLayer,-1).timeRemap+.0417
  • Kevin Camp
    February 1, 2013 at 7:00 pm
    if you have each frame physically flipping on, then i would think you’d just need to sequence the layers (animation>keyframe assistant>sequence layers…)
    there is also this tutorial that uses cc page turn and time remapping:
    https://library.creativecow.net/articles/kramer_andrew/flipbook.php
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Ted Intorcio
    February 8, 2013 at 8:21 pm
    Cool Thanks!
